Debug IAP-CAP conversion progess in AP side
  • 1.  Debug IAP-CAP conversion progess in AP side
    Posted Mar 19, 2018 06:51 AM
    Hi!
    Is there any debug or show command on Aruba Instant OS to check how the conversion progess go, is it finished successfully or not?
    We find that sometimes you do it properly, but in many cases, nothing happens after the release of the convert-aos-ap command in the cluster, even if you type it several times with a few minutes difference.
    Sometimes it happens to start the reboot (one would think the conversion was done) but it will come back with Instant software as well.
    IAP cli shown this:
    xx:xx:xx:xx:xx:xx# convert-aos-ap cap x.x.x.x
    Converting to Controller based AP. Will automatically reboot when done.
    We access only the AP side, not the controller.
    Any advice for AP side debugging to see what happening?
    Thanks!
  • 2.  RE: Debug IAP-CAP conversion progess in AP side
    Posted Mar 19, 2018 07:16 AM
    show log upgrade
    show log system
  • 3.  RE: Debug IAP-CAP conversion progess in AP side
    Posted Mar 19, 2018 07:29 AM
    Thanks, I will try it and reply.
  • 4.  RE: Debug IAP-CAP conversion progess in AP side
