Probably a basic question but I apparently haven't got a clue..
Is there any command to see basic statisticsof ip-helpers?
How can I get some more visibility in the ip-helper process?
What debug will show me ip helper stuff?
Logging level debugging network dhcpWill give you some visibility.
<EDIT>
Correct command is logging level debugging network subcat dhcp
Found by koenv.
uch, too obvious I guess.
correct command would be configure terminal logging level debugging network subcat dhcp btw :)
Thanks!
