Debugging DHCP process with when the controller is the client
  • 1.  Debugging DHCP process with when the controller is the client
    Posted Jun 25, 2018 08:32 AM
    Hello all,
    I can't debug the packets sent on dhcp when the controller is the client.
    I have the server in the same Lan but I cannot acces to it, I need to follow the process from the controller POV
    Tried with:
    packet-capture reset-pcap controlpath-pcap
     packet-capture destination local-filesystem
     packet-capture controlpath udp 67,68
    show packet-capture controlpath-pcap
    <no result with controller packets>
    packet-capture reset-pcap datapath-pcap
    packet-capture datapath mac <controller-mac> all
    <no result at all>
    packet-capture datapath mac <dhcp-server-mac> all
    <no result at all>
    logging network subcat dhcp level debugging
    <no really sure about this>
  • 2.  RE: Debugging DHCP process with when the controller is the client
    MVP EXPERT
    Posted Jun 25, 2018 08:35 AM
    The dhcp debugging command you listed usually works for me.What are you trying to achieve? Have you tried running a pcap on the client as well?
  • 3.  RE: Debugging DHCP process with when the controller is the client
    Posted Jun 25, 2018 09:46 AM
    This commands work fine for me when the controller is the DHCP server.
    But I have an vlan on the controller set as dhcp client and the controller dhcp packets (neither discover or request) are not shown on the controlpath nor the datapath
  • 4.  RE: Debugging DHCP process with when the controller is the client
    Posted Jun 26, 2018 07:41 AM
    Hi Pedro,
    I can recommend you try the logging options of the controller. In this case, a debug of the process fpapps (layer 2 and 3 control) may be help you with your problem.
    #logging network process fpapps level debugging
    #show logging level verbose
    LOGGING LEVELS
    Facility  Level     Sub Category  Process
    arm       warnings  N/A           N/A
    network   debugging N/A           fpapps
    security  warnings  N/A           N/A
    system    warnings  N/A           N/A
    user      warnings  N/A           N/A
    wireless  warnings  N/A           N/A
    You can obtain the logs with the next command (I recommend you play with "include" and "begin" options)
    #show log all | include fpapps | include DHCP
    When you finish, remember to disable it:
    #no  logging network process fpapps
    LOGGING LEVELS
    network   warnings  N/A           N/A
    You can obtain more info in this link. :)
  • 5.  RE: Debugging DHCP process with when the controller is the client
    Posted Jun 26, 2018 09:14 AM
    Wow this answer really worked for me, ipenido
    Thank you very much!
