Dedicated vlans for vrrp?
  • 1.  Dedicated vlans for vrrp?
    Posted Feb 20, 2014 09:16 AM
    I am confiuguring VRRP for AP failover between 4 controllers (master/local/local/local) and wonderd if I should be using a dedicated vlan or could I simply use an address from an existing user vlan?
    We have a layer2 managment vlan for the controllers, and 8 vlans for wifi clients.  Could I use one or several of these vlans for vrrp, or would it be best practice to have each vrrp instance on its own dedicated vlan?
    Thanks.
  • 2.  RE: Dedicated vlans for vrrp?
    Posted Feb 20, 2014 09:25 AM
    You should use the same management VLAN you already have dedicated for the controllers.
  • 3.  RE: Dedicated vlans for vrrp?
    Posted Feb 20, 2014 10:11 AM
    Thanks.. so therefore, if I have multiple vrrp instances due to spreading the ap groups across the controllers, I should have them on their rown vlans?
  • 4.  RE: Dedicated vlans for vrrp?
    Posted Feb 20, 2014 10:15 AM
    You don't have to but if you would like to go for it
