Default and recommended logging enabled on ARuba controller?
  • 1.  Default and recommended logging enabled on ARuba controller?
    Posted Mar 12, 2017 07:41 AM
    What are the default logging that are enabled on the ARuba controller?
    I am running on 6.5.0.2. As part of several troubleshooting I had few of them enabled over the course of time, and not able to conclude whether these are enabled by default or had been done manually.
    (WLC_0001) #show running-config | include logging
    Building Configuration...
    voice logging
    logging level debugging network process dhcpd
    logging level debugging network process dhcpd subcat dhcp
    logging level debugging network subcat dhcp
    logging level warnings security subcat ids
    logging level warnings security subcat ids-ap
    Can someone please confirm whether there any any logging that are enabled by default on the controller?
    Is there any recommendation to have certain logging enabled throughout on the controller for ease of troubleshooting without compromising the CPU on the Controller?
  • 2.  RE: Default and recommended logging enabled on ARuba controller?
    Posted Mar 12, 2017 07:48 AM
    The best is warnings on the top level.  Warnings provide the best top-level logging.  You can enable more if you want to dive deeper into something:  http://www.arubanetworks.com/techdocs/ArubaOS_65x_WebHelp/Web_Help_Index.htm#ArubaFrameStyles/1CommandList/logging_level.htm
    You can also reset everything to warnings by typing:
    Aruba7640-US) (config) #no logging level
    (Aruba7640-US) (config) #show logging level verbose
    LOGGING LEVELS
    Facility  Level     Sub Category  Process
    arm       warnings  N/A           N/A
    network   warnings  N/A           N/A
    security  warnings  N/A           N/A
    system    warnings  N/A           N/A
    user      warnings  N/A           N/A
    wireless  warnings  N/A           N/A
  • 3.  RE: Default and recommended logging enabled on ARuba controller?
    Posted Mar 12, 2017 09:52 PM
    Just an FYI, I had a similar number of debug logs running on my controller at one point and it started causing issues on the controller. I wouldn't run any debug logs for a extended amount of time, especially several of them at once.
