Default ArubaOS config
  • 1.  Default ArubaOS config
    Posted Mar 24, 2014 11:51 AM
    We are using ArubaOS on a 6000/M3 controller that has had many configuration changes since it was originally set up years ago.  I'm interested to see what the factory default configuration file would look like in order to compare it with our current configuration.  Unfortunately I don't see that any copies exist on the controller.  Is there any way to get a default config file from the controller or other means?
  • 2.  RE: Default ArubaOS config
    Posted Mar 24, 2014 12:51 PM
    What ArubaOS are you looking for?
  • 3.  RE: Default ArubaOS config
    Posted Mar 24, 2014 01:10 PM
    Our current version is 6.3.1.3.
  • 4.  RE: Default ArubaOS config
    Posted Mar 24, 2014 01:55 PM
    Default 6.3.1.3 configuration attached.
    Attachment(s)
    txt
    6.3.1.3-default.txt   17 KB 1 version
  • 5.  RE: Default ArubaOS config
    Posted Mar 24, 2014 02:23 PM
    Thank you!
  • 6.  RE: Default ArubaOS config
    Posted Sep 12, 2017 03:05 AM
    Where can I get that for other versions (6.4.4.10 , 6.5.3.2) ? Is there any way other then write erase on a controller or asking here? Is it published somewhere?
  • 7.  RE: Default ArubaOS config
    Posted Sep 12, 2017 09:24 AM
    They have to be captured from a defaulted controller at whatever specific version you need. That said, default configs don't change that often.
