default credentials for IAP 345
  • 1.  default credentials for IAP 345
    Posted Oct 20, 2021 08:02 AM
    Had some  APs that were factory reset using a paper  clip. Turns out they were IAPs. Now looking at a  gui login prompt  usual admin/admin admin/password  combinations dont work.
    What might the default credentials be?
    Rgds
    Alex
    Alex Sharaz
  • 2.  RE: default credentials for IAP 345
    MVP GURU
    Posted Oct 20, 2021 08:52 AM
    Use the serial number of the AP as the password. Username is still admin.
    Dustin Burns
    Lead Mobility Engineer @WEI
    ACCX 1271| ACMX 509| ACSP | ACDA | MVP Guru 2021
  • 3.  RE: default credentials for IAP 345
    Posted Oct 20, 2021 03:17 PM
    And it worked
    Many thanks
    A
    Sent from my iPhone
