Wired Intelligent Edge
default gateway for IDF switches
  • 1.  default gateway for IDF switches
    Posted Nov 09, 2018 12:55 PM
    I have CoreSw1 with below vlan and ip address:
    vlan 1 -> 10.1.1.1
    vlan 2 -> 10.1.2.1
    vlan 3 -> 10.1.3.1
    vlan 4 -> 10.1.4.1
    I have IDF1 and IDF2 connected to the CoreSw1. Both switch have only one ip address for vlan1 as:
    IDF1 -> 10.1.1.2
    IDF2 -> 10.1.1.3
    Can I set ip default-gateway for both IDF switches to any vlan ip address of the CoreSw1?
  • 2.  RE: default gateway for IDF switches
    Posted Nov 09, 2018 01:02 PM
    Greetings!
    You would set the default gateway to the IP address in the same subnet as the IP on the switch you're configuring (so, presuming that these are /24 subnets, you would set the default gateways on IDF1 and IDF2 to 10.1.1.1).
  • 3.  RE: default gateway for IDF switches
    Posted Nov 09, 2018 01:57 PM
    Hi Matt,
    So why I cannot set 10.1.2.1 or 10.1.3.1 or 10.1.4.1?
  • 4.  RE: default gateway for IDF switches
    MVP GURU
    Posted Nov 10, 2018 11:51 AM
    @Nick IT wrote:
    Hi Matt,
    No, need to be on the same subnet
  • 5.  RE: default gateway for IDF switches
    Posted Nov 12, 2018 09:06 AM
    What will happen if it set to different vlan ip address as def. gateway?
    Also if give ip address to vlan 3 on the IDF switches, can I set def. gateway for the vlan?
  • 6.  RE: default gateway for IDF switches
    Posted Nov 13, 2018 09:33 AM
    Maybe you are allowed to add those default routes, but IDF1/2 will think: whatever network I have to reach, throw the packet to default gateway 10.1.3.1, but where is that IP address?, does it belong to a network where I have a virtual interface?, the answer is: No, I only have a virtual interface on 10.1.1.0/24, I do not have a virtual interface in network 10.1.3.0/24, so I cannot throw the packet to next hop 10.1.3.1, so the packet is discarded.
    Hope this helps you. Please give some extra kudos.
    Pedro
