Default login not working on AP-303HR
  • 1.  Default login not working on AP-303HR
    Posted Dec 30, 2018 11:04 AM
    Attempting to set up the first AP-303HR in Instant mode (and let the rest replicate from that one), but login fails from the Welcome to Instant, Virtual Controller screen. Have tried admin/admin as well as root/admin and admin/root, that was used in some of Aruba's other products and all keep saying Login failed.
    They have been reset numerous times. They are US versions and are brand new. No, I do not know what Aruba OS version they are running, but I havent seen Aruba change the default name/password through all the different OS versions.
    Any ideas on alternate login(s) or what is going wrong?
  • 2.  RE: Default login not working on AP-303HR
    Posted Dec 30, 2018 11:07 AM
    Apologies on the double post. Ignore this one.
  • 3.  RE: Default login not working on AP-303HR
    Posted Dec 30, 2018 11:09 AM
    Are you trying to login to it on the GUI or via SSH?  Are these devices new, or could someone have provisioned them to the cloud previously?
    EDIT:  Have you tried the factory reset procedure?  https://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/Command/Core_Download/Default.aspx?EntryId=31399
  • 4.  RE: Default login not working on AP-303HR
    Posted Apr 04, 2020 05:22 AM
    I have the same problem. I bought a new aruba 300 series campus access point for home use.
    I can see the "Welcome to Instant" web page and have no clue what the user/password is. I cannot find any documentation that states what it is.
    I can also ssh to the aruba but again no idea what the user/password is. I factory reset it and still no luck.
    If anyone out there knows the user/password please let me know.
  • 5.  RE: Default login not working on AP-303HR
    MVP GURU
    Posted Apr 04, 2020 12:03 PM
    Have you tried admin for user and the serial number for password?
  • 6.  RE: Default login not working on AP-303HR
    Posted Apr 04, 2020 03:29 PM
    Thank you that helped! I should have guessed it is the serial number.
    I hope this information gets added to the ArubaOS Quick Start Guide and User's Guide.
    Thank you so much!
