Aruba Apps
The HPE Aruba Networking Apps board is designed to address questions, comments, and feature requests for all HPE Aruba Networking mobile Apps
Default Router vs VLAN IP
  • 1.  Default Router vs VLAN IP
    Posted Feb 20, 2020 04:53 PM
    Hello, guys.
    I am trying to config a guest SSID in an IAP cluster, no controller. All right. I understand that, If I want the IAP cluster to act as the DHCP server and some interface at the switch to be the default gateway, I need to set up the DHCP Scope for a Local, L2. Is that right?
    Now, the Local, L2 has two terms that seem the same to me. What is the difference between "default router" and VLAN IP?
    I mean, there is a VLAN-interface in the switch, with an IP address (10.30.0.254) and the customer wants this interface to be the default gateway (its his current setup) for this VLAN. Where do I inform this 10.30.0.254. Is it the default router or the VLAN IP?
    Thanks for your help!
  • 2.  RE: Default Router vs VLAN IP
    MVP GURU
    Posted Mar 30, 2020 08:28 AM
    You would put both. The VLAN IP will be needed for captive portal redirect, and you can also use it as the default gateway for that VLAN.
