Default Session Timeout Option
  • 1.  Default Session Timeout Option
    Posted Nov 15, 2012 04:48 PM
    Aruba ClearPass Guest OS release 3.9, Guest users that go inactive within 5 mins have to relogin.  where can I extend?
  • 2.  RE: Default Session Timeout Option
  • 3.  RE: Default Session Timeout Option
    Posted Nov 15, 2012 06:51 PM
    Do a search for "caching" in the help and you will come across a topic "Configuring MAC Caching During User Authentication"
  • 4.  RE: Default Session Timeout Option
    Posted Nov 16, 2012 10:50 AM
    found document and navigated to the specific area and do not have the 'MAC Cache' option available.  Is it a particular attribute that I need to add?
  • 5.  RE: Default Session Timeout Option
    Posted Nov 16, 2012 11:01 AM
    Shouldn't be an attribute.  Should be a check box near the bottom of your Radius User Role on Clearpass, called MAC Cache.  Should just need to check the box.   Attached a screen shot.
  • 6.  RE: Default Session Timeout Option
    Posted Nov 16, 2012 11:03 AM
    dont have that option available for any user role profile.. see attached
  • 7.  RE: Default Session Timeout Option
    Posted Nov 16, 2012 11:06 AM
    What version of Amigopod do you have?  You might have to check for updates..
  • 8.  RE: Default Session Timeout Option
    Posted Nov 16, 2012 11:15 AM
    If you don't have that option, you might look through this thread.  This really helped me when I had timeout issues and there are some tips here for dealing with Laptops going to sleep even:
    http://community.arubanetworks.com/t5/ArubaOS-and-Mobility-Controllers/Captive-portal-timeout-issues/td-p/20554
    Also make sure you actually are running 3.9.  The version from my screenshot is fully patched as of 8am this morning.
  • 9.  RE: Default Session Timeout Option
    Posted Nov 16, 2012 11:25 AM
    No updates required
    Cleaning up OS update state:
    Loaded plugins: fastestmirror
    Cleaning up Everything
    Cleaning up list of fastest mirrors
    0 metadata files removed
    0 sqlite files removed
    Checking for available updates:
    Determining fastest mirrors
    amigopod-base.x86_64              3.9.4-2                               amigopod
  • 10.  RE: Default Session Timeout Option
    Posted Nov 16, 2012 11:27 AM
    Please open a support case to ensure the integrity of your plugins.
  • 11.  RE: Default Session Timeout Option
    Posted Nov 16, 2012 11:30 AM
    just noticed this:
    No plugins are available for installation at this time due to an error.
    Your subscription has expired, so you can no longer receive updates. Please contact your reseller to renew your subscription.
