Default size of SAP MTU on 7240 controller?
This thread has been viewed 112 times
  • 1.  Default size of SAP MTU on 7240 controller?
    Posted Feb 21, 2014 09:44 AM
    We have a couple of new 7240s running 6.3.1.2 code that have a SAP MTU setting of 1300.  Did the default size change from 1500?  These were set up by another tech so I am not sure if this was done during config or if the default setting has changed for some reason.
    #7240
  • 2.  RE: Default size of SAP MTU on 7240 controller?
    Posted Feb 21, 2014 10:01 AM
    Is this in the AP sys profile?  Is there a value in that field in the UI?
    #7240
  • 3.  RE: Default size of SAP MTU on 7240 controller?
    Posted Feb 21, 2014 10:21 AM
    Yes, this is the AP System default profile.  Currently set to 1300.
    #7240
  • 4.  RE: Default size of SAP MTU on 7240 controller?
    Posted Feb 21, 2014 10:34 AM
    If you see a value in there, it's not the default.
    #7240
  • 5.  RE: Default size of SAP MTU on 7240 controller?
    Posted Feb 21, 2014 11:24 AM
    So the default is blank which would be auto discovery of MTU size?
    #7240
  • 6.  RE: Default size of SAP MTU on 7240 controller?
    Posted Feb 21, 2014 04:55 PM
  • 7.  RE: Default size of SAP MTU on 7240 controller?
    Posted Feb 21, 2014 05:09 PM
    I see that it says it sends 1576 byte frames to detect if jumbo frames are supported, but it doesn't really address how it would determine MTU size if left blank.
    #7240
  • 8.  RE: Default size of SAP MTU on 7240 controller?
    Posted Feb 21, 2014 05:20 PM
    I'm sure there's logic built into AOS that says if the value is blank than use a default value (I assume 1576 based on the link provided).  I can't find anything in the reference guides as conclusive proof, but I think you would find this to be true if you removed the current value and performed a packet capture where the AP is connected.
    --- Edit ---
    Just found the following command that should show you the SAP value.  You could try deleting the current value and then issue this command:
    show ap debug received-config ap-name XXXXXX
    #7240
  • 9.  RE: Default size of SAP MTU on 7240 controller?
    Posted Feb 25, 2014 10:01 AM
    Good call!  I have tested this and it does indeed default to 1500 when this field is left blank.
    #7240
