Hello everyone,
after searching the forums several times without finding something regarding my problem, I guess I need to start a new topic for this:
After switching back and forth between different AOS versions (8.1, 8.0, 6.5 and 6.4) on my lab controllers, I am unable to connect to them using https or ssh after boot. The browser is not showing any certificate for the controllers ip address.
After issuing the command "restore factory_default certificate" https and ssh work again, as long as the controllers are powered on. After next restart I need to execute the command over serial again in order to get https and ssh access to the controllers.
The last thing I tried in order to solve the problem was wiping the flash without any success.
I appreciate any help with the issue
Martin
