Define My OwnText IDs
  • 1.  Define My OwnText IDs
    Posted Jul 22, 2016 12:17 PM
    I want to add additional text-translation areas in my html code using the {nwa_text id=} tag.  Can I take an undefined text id (ie text id=5000) and define it for use in my code?
    Thanks.
  • 2.  RE: Define My OwnText IDs
    MVP GURU
    Posted Jul 25, 2016 10:39 AM
    Thanks.
    You can add on "Guest Portal" => Configuration => Translations => Translations Pack => Chooce your language => Override Translations
    And Set a Text ID (like 20000 for example)
