Wired Intelligent Edge
Defining local user-roles for use in event cppm not contactable
  • 1.  Defining local user-roles for use in event cppm not contactable
    Posted Jul 04, 2022 08:52 AM
    I'm successfully using downloadable user roles  via clearpass and now need to configure some local ones  in the event cppm is not accessible. (Switch code WC.16.10.21)
    Thought I'd try something simple  so the allowall roole below should just let the client  connect via the statically defined vlan/port assignment. Got DHCP/DNS and allowall classes, at a later date the allowall class will be replaced with something   more representative
    Unfortunately, it doesnt work.
    I have
    aaa port-access 1/1 critical-auth user-role allowall
    Looking through the session logs when i forcve a reauth I can see
    "dca: ST1-CMDR: Failed to apply user role to macAuth client <macaddress> on port 1/1: user role is invalid"
    Aruba-2930F# show user-role allowall detailed
    User Role Information
    Type : local
    Reauthentication Period (seconds) : 3600
    Cached Reauth Period (seconds) : 0
    Logoff Period (seconds) : 300
    Untagged VLAN :
    Tagged VLAN :
    Captive Portal Profile :
    Policy : AllowAll
    Statements for policy "AllowAll"
    policy user "AllowAll"
    10 class ipv4 "DHCP" action permit
    20 class ipv4 "DNS" action permit
    60 class ipv4 "allowall" action permit
    exit
    Statements for class IPv4 "DHCP"
    class ipv4 "DHCP"
    10 match udp 0.0.0.0 255.255.255.255 0.0.0.0 255.255.255.255 eq 67
    exit
    Statements for class IPv4 "DNS"
    class ipv4 "DNS"
    10 match udp 0.0.0.0 255.255.255.255 0.0.0.0 255.255.255.255 eq 53
    exit
    Statements for class IPv4 "allowall"
    10 match ip 0.0.0.0 255.255.255.255 0.0.0.0 255.255.255.255
    exit
    Tunnelednode Server Redirect : Disabled
    Secondary Role Name :
    Device Attributes : Disabled
  • 2.  RE: Defining local user-roles for use in event cppm not contactable
    Posted Jul 04, 2022 10:37 AM
    Should say that cppm is in monitor mode and not sending back a user-role. Even get the message when  I've assigned an explicit initial user-role, so is the log just telling me that it hasnt seen a downloaded user-role?
    if I do show port-access 1/1 client
    it shows that it has role "allowall" applied
    A
  • 3.  RE: Defining local user-roles for use in event cppm not contactable
    Posted Jul 06, 2022 07:07 AM
    Hi Alex,
    For me it looks like the CPPM is returning access accept messages only (CPPM Monitor mode: https://community.arubanetworks.com/community-home/digestviewer/viewthread?MID=22277) and these messages are having the wrong/or missing VSAs (https://community.arubanetworks.com/blogs/esupport1/2020/04/10/arubaos-switch-error-message-05204-dca-failed-to-apply-user-role-reported-in-the-log-file).
    The error message is kind of confirming this (Description: User role VSA received for the client is invalid or does not exist.)
    Event ID: 5204: https://support.hpe.com/hpesc/public/docDisplay?docId=a00093582en_us
    Did you try the critical authentication with no connection to the CPPM?
  • 4.  RE: Defining local user-roles for use in event cppm not contactable
    Posted Jul 06, 2022 09:39 AM
    Yes I tried that on my dev server nasty home.
    At home I have
    class ipv4 "DNS"
    10 match udp 0.0.0.0 255.255.255.255 192.168.1.152 0.0.0.0 eq 53
    20 match udp 0.0.0.0 255.255.255.255 192.168.2.4 0.0.0.0 eq 53
    30 match udp 0.0.0.0 255.255.255.255 192.168.1.88 0.0.0.0 eq 53
    exit
    class ipv4 "DHCP"
    exit
    class ipv4 "ICMP"
    10 match icmp 0.0.0.0 255.255.255.255 0.0.0.0 255.255.255.255
    exit
    exit
    30 class ipv4 "ICMP" action permit
    exit
    aaa authorization user-role name "servers"
    policy "AllowAll"
    reauth-period 3600
    vlan-name "servers"
    exit
    aaa authorization user-role name "allowall"
    policy "AllowAll"
    reauth-period 3600
    exit
    aaa authorization user-role name "critical-role"
    policy "AllowAll"
    reauth-period 3600
    exit
    aaa authorization user-role name "aruba-instant-ap"
    policy "AllowAll"
    reauth-period 3600
    vlan-name "DEFAULT_VLAN"
    vlan-id-tagged 2-6,10,111,222,333
    device
    poe-allocate-by-class
    admin-edge-port
    port-mode
    exit
    exit
    And finally …..
    aaa port-access 2 auth-order authenticator mac-based
    aaa port-access 3 controlled-direction in
    aaa port-access 3 auth-order authenticator mac-based
    aaa port-access 3 auth-priority authenticator mac-based
    aaa port-access 3 critical-auth user-role "aruba-instant-ap"
    aaa port-access 4 controlled-direction in
    aaa port-access 4 auth-order authenticator mac-based
    aaa port-access 4 auth-priority authenticator mac-based
    aaa port-access 4 critical-auth user-role "aruba-instant-ap"
    aaa port-access 5 controlled-direction in
    aaa port-access 5 auth-order authenticator mac-based
    aaa port-access 5 auth-priority authenticator mac-based
    aaa port-access 5 critical-auth user-role "aruba-instant-ap"
    aaa port-access 6 controlled-direction in
    aaa port-access 6 auth-order authenticator mac-based
    aaa port-access 6 auth-priority authenticator mac-based
    aaa port-access 7 controlled-direction in
    aaa port-access 7 auth-order authenticator mac-based
    aaa port-access 7 auth-priority authenticator mac-based
    aaa port-access 7 critical-auth user-role "servers"
    aaa port-access 8 controlled-direction in
    aaa port-access 8 auth-order authenticator mac-based
    aaa port-access 8 auth-priority authenticator mac-based
    aaa port-access 8 critical-auth user-role "aruba-instant-ap”
    Had a power cut at home and switches came back before cppm and ended up getting the following
    W 07/06/22 09:58:23 05204 dca: Failed to apply user role to macAuth client
    5AC41408495B on port 4: user role is invalid.
    W 07/06/22 09:58:13 05204 dca: Failed to apply user role to macAuth client
    DC4F22EC13FC on port 4: user role is invalid.
    W 07/06/22 09:58:12 05204 dca: Failed to apply user role to macAuth client
    DC4F22F2D31E on port 3: user role is invalid.
    W 07/06/22 09:58:10 05204 dca: Failed to apply user role to macAuth client
    1C30080934EE on port 4: user role is invalid.
    W 07/06/22 09:58:09 05204 dca: Failed to apply user role to macAuth client
    8A1E274C75F1 on port 4: user role is invalid.
    140AC5ACAD9D on port 4: user role is invalid.
    W 07/06/22 09:58:08 05204 dca: Failed to apply user role to macAuth client
    C8E265001B76 on port 3: user role is invalid.
    The above relate to an Aruba instant AP which should have been in port mode so I shouldn’t have seen them. When cppm is there and I’m using DUP, works just fine
    A
  • 5.  RE: Defining local user-roles for use in event cppm not contactable
    Posted Jul 07, 2022 06:05 AM
    Hi Alex,
    Have you tried to enable debugging to see more details?
    You can try the debugs for port-access and radius (debug security port-access/radius).
