Delaying dhcp request on AP225
  • 1.  Delaying dhcp request on AP225
    Posted Dec 11, 2014 07:54 AM
    Got a problem with a combination of an AP225 and an HP 5130 switch stack. The actual problem is to do with the 5130 but I'm wondering if there's anything I can do on the 225 to get round the problem
    Our switch ports are configured to support both 802.1x and mac auth. A successful authentication results in cleapass passing back a vlan name to the switch and the client device is placed in the appropriate vlan. For a failed authentication, the switch drops the client into an "unauth" vlan with limited network access.
    This is something we do all over campus on our HP Procurve switches. The 5130 is a rebadged H3C switch running ComWare Vsn 7
    I'm getting a race condition where the sequence of events seems to be as follows:-
    power up AP via PoE+ from switch
    switch puts AP in catch all vlan
    Switch sees (dhcp)  traffic from AP and start processng a mac-auth
    ap requests an IP address and gets one associated with the "unauth" vlan
    switch finishes processing the mac_auth and places AP into the correct vlan
    AP has IP associated with one vlan but is in another one
    Eventually AP reboots because it can't "phone home" to the mobility controller and sequence starts again.
    Now the problem is that the switch shouldn't proces the dhcp request until after either a mac-auth or 802.1x auth request has been processed/timed out. If it did that then things would be just fine and the AP would get an IP address on the right vlan.
    While I could put a silly lease time in for the DHCP pool associated with the "unauth" vlan, that would affect everything connected to it which would be a bit silly. Is there any way of configuring the AP to delay the dhcp request for a couple of seconds to give the switch enough time to process the mac-auth?
    Rgds
    Alex
    #AP225
  • 2.  RE: Delaying dhcp request on AP225
    Posted Dec 11, 2014 07:59 AM
    Do you see the same behavior if you use 802.1X with the AP?
    #AP225
  • 3.  RE: Delaying dhcp request on AP225
    Posted Dec 11, 2014 08:34 AM
    Didn't know I could. Need to do some reading.
    Rgds
    Alex
    #AP225
  • 4.  RE: Delaying dhcp request on AP225
    Posted Dec 11, 2014 08:36 AM
    Easiest thing to do is create a local user in clearpass with a tips role of AP. Then in the AP provisioning screen you can specify 1X credentials.
    #AP225
  • 5.  RE: Delaying dhcp request on AP225
    Posted Dec 11, 2014 08:47 AM
    cool,
    I'll give it a try
    A
    #AP225
