Delete and unassign IAP in Aruba Central
  • 1.  Delete and unassign IAP in Aruba Central
    Posted Jul 30, 2019 06:17 AM
    I tried the trial version of Aruba Central on my IAP. The demo period is not over yet, now I want to connect my IAP to the Aruba Mobility Controller, but it continues to connect to Aruba Central.
    steps I tried:
    1) I removed the licence from the IAP in Subscription Assignment.
    2) Deleted the down IAP in the Monitoring&Reports.
    3) I factory resetted the IAP.
    and anyway when turned on it connects to Aruba Central.
    there is a solution?
  • 2.  RE: Delete and unassign IAP in Aruba Central
    MVP EXPERT
    Posted Jul 30, 2019 06:35 AM
    The steps you have completed should remove it from Central. When you browse to the IAP does it show as locally managed? Do you have the option to convert to CAP?
  • 3.  RE: Delete and unassign IAP in Aruba Central
    Posted Jul 30, 2019 08:40 AM
    When I connect to the AP I see this page, by default the login and password do not fit
  • 4.  RE: Delete and unassign IAP in Aruba Central
    MVP EXPERT
    Posted Jul 30, 2019 08:45 AM
    What version of 8.x code is this? In later versions (8.5+) you will need to login with the password being the IAPs serial number.
  • 5.  RE: Delete and unassign IAP in Aruba Central
    Posted Jul 30, 2019 09:09 AM
    Yes thanks, it worked
