Delete SSID in Aruba OS 8.6.4.0
  • 1.  Delete SSID in Aruba OS 8.6.4.0
    MVP
    Posted Jul 16, 2020 02:39 AM
    I have created a test ssid in 7205 controller running OS ver 8.6.4.0. When I try to delete it, its giving error message "Operations on AAA Profile "IH-TEST_aaa_prof" will not take effect: configuration is inherited". How can I delete it?
  • 2.  RE: Delete SSID in Aruba OS 8.6.4.0
    Posted Jul 16, 2020 04:08 AM
    Configuration can be done on every level of the hierarchy and will be effective also on lower levels. Example: if I configure an SSID on Managed Network level, it will also be active on ArubaLAB and on md7005.
    If you see that message, the configuration was done before on a higher level than where you now try to remove it. Move up (you can click on the labels) and try to delete it there.
  • 3.  RE: Delete SSID in Aruba OS 8.6.4.0
    MVP
    Posted Jul 16, 2020 04:14 AM
    Thank you. That worked!
