Network Management
deleting devices on Airwave
  • 1.  deleting devices on Airwave
    Posted Nov 08, 2018 09:20 AM
    Hi Comunnity
    I use Airwave 8.2.4.1 and I am trying to delete some devices from one group. Initially I had 31 devices and I deleted 13. I can't delete the rest 18 devices. Any recommedation?
    Best regards
    Karlink
  • 2.  RE: deleting devices on Airwave
    Posted Nov 08, 2018 12:49 PM
    Are you deleting individually from the Device's manage page?  Or are you doing bulk deletes from a list view?  If the device's aren't getting deleted after you'd set them to be deleted, then next step should be opening a TAC case so that they can investigate if there's any locks in the database for those objects.
