Deletion of clearpass guest accounts
  • 1.  Deletion of clearpass guest accounts
    Posted Jul 21, 2020 05:43 AM
    Been revisiting setting up a basic clearpass guest service whare a visitor has time-limited access to a guest portal based service.
    When I did this about 5 years ago i could delete an account after it expired so if the user tried to re register things would "just work"
    AFAIK this has now been depreciated in favor of a Policy Manager global setting for clearing out guest users. Unfortunately the minimum deletion period is 1 day
    So ....
    User registers for visitor access at 9am ( iinitial login, subsequent mac caching)
    System grants them  2 hours access
    11am account expires
    User then wants to connect again  ..
    ... but can;t because account has expired ( not deleted)
    cronjob (?) purges their account  i assume at  main period ~2am ish
    If the above is correct , why the depreciation  of user account deletion at expiry time in favour of a global setting thast can only run once a day minimum?
    A
  • 2.  RE: Deletion of clearpass guest accounts
    Posted Jul 21, 2020 09:13 AM
    So you want the guest user to be able to register again with the same account after its account expired?
    Why not try to use auto_update_account
    https://www.arubanetworks.com/techdocs/ClearPass/6.7/Guest/Default.htm#Configuration/BusinessLogicForAccountCreation.htm?Highlight=auto_update_account
  • 3.  RE: Deletion of clearpass guest accounts
    Posted Jul 21, 2020 09:27 AM
    Because didn't know it existed. Many thanks for that, I'll go have a play
    Rgds
    Alex
  • 4.  RE: Deletion of clearpass guest accounts
    Posted Jul 21, 2020 09:30 AM
    Ah! in fact its enabled by default when you use the template to create a guest user account ..
