Dell W-IAP205
  • 1.  Dell W-IAP205
    Posted Jan 16, 2017 06:32 PM
    Hi team,
    Dell W-IAP205 is similar to Aruba IAP-205?
    Dell W-IAP205 is compatible with Aruba Airwave?
    Regards
    Attachment(s)
  • 2.  RE: Dell W-IAP205
    Posted Jan 16, 2017 08:33 PM
    Yes to both.
  • 3.  RE: Dell W-IAP205
    Posted Jan 18, 2017 08:49 AM
    Thanks for your reply.
    It would be advisable to have them in the same cluster.
    Regards.
  • 4.  RE: Dell W-IAP205
    Posted Jan 18, 2017 09:15 AM
    Do not put Dell and Aruba IAPs in the same cluster.  It is not designed for such use,  it is not supported, it is not tested or QA'ed that way and we will not offer help to anyone who is trying to deploy that solution.
