Denon Heos
This thread has been viewed 23 times
  • 1.  Denon Heos
    Posted Nov 26, 2020 12:35 PM
    does anyone know how to configure an iap 325, so I can see my Denon and Heos speakers?
    regards
    leo
    Leo Blok
  • 2.  RE: Denon Heos
    Posted Nov 27, 2020 12:41 PM
    I am not sure about these speakers..but are they on the same vlan as the client device? If yes, did you try to disable broadcasting filtering under the SSID settings?
    Ayman Mukaddam
  • 3.  RE: Denon Heos
    Posted Nov 27, 2020 01:13 PM
    yes and yes.
    thx for your answer
    Leo Blok
  • 4.  RE: Denon Heos
    Posted Nov 30, 2020 04:28 AM
    Did you enable airgroup?
    https://www.arubanetworks.com/techdocs/Troubleshooting/ArubaOS/AirGroup_Troubleshooting/Web_Help_Index.htm#arubaframestyles/troubleshooting%20topics/airgroup.htm%3FTocPath%3D_____2
    Dave
