Deny inter user traffic per role?
  • 1.  Deny inter user traffic per role?
    Posted Jul 03, 2018 12:47 PM
    Is there a user-role specific way to accomplish this same level of blocking?
    What I am trying to accomplish is this:
    I have an Open Guest network that returns the role guest.
    I would like to put another set of devices that cannot user 802.1x on the guest network, but the devices need to be able to communicate with eachother.
    Right now I have deny inter user traffic enabled on the VAP. My thought is I need to remove that option, and move it to the guest user role.
    The only solution I've come up with is an ACL, which is not ideal since I can't do an ACL that says user user any deny, since it wants source/destination to be different. So I would need to create ACLs specific to sites.
  • 2.  RE: Deny inter user traffic per role?
    MVP EXPERT
    Posted Jul 03, 2018 05:48 PM
    You maybe make a acl like...
    Src: User
    Dest: 10.0.0.0 / 255.0.0.0
    Dest: 172.16.0.0 / 255.240.0.0
    Dest: 192.168.0.0 / 255.255.0.0
    Deny
    Or create a guest ssid with deny inter user traffic and a second ssid “contractor” where you allow that.
  • 3.  RE: Deny inter user traffic per role?
    Posted Jul 04, 2018 01:51 AM
    I think that you should limit traffic to the role you are assigned to using the bandwidth option in your role.
  • 4.  RE: Deny inter user traffic per role?
    Posted Jul 05, 2018 05:21 AM
    Hi Eugene,
    Won't the following acl's help ?
    any <gateway ip> any permit
    any <guest network> any deny
    any any any permit
  • 5.  RE: Deny inter user traffic per role?
    Posted Jul 06, 2018 01:10 PM
    Yes this would work, and is what I meant by ACL specific to sites.
    I was hoping there was an option I missed that was an easy checkmark in the user-role!
    Thanks!
