Deploy RAP in L3 network environment
  • 1.  Deploy RAP in L3 network environment
    Posted Jun 09, 2023 10:59 AM
    in some small branch offices connected with L3 network, I need to have local forwarding for guest ssid and local resources.
    I have the virtual mobility controllers in the datacenter, can I configure the campus AP to forward in local teh guest network and remain up also without controller?
    If not possible with CAP, can I convert the AP305 or 304 in rap and use it? it should have a controller dedicated? or can I use a controller already in the cluster?
    Dario Nardello
    ACMP ACSP ACCP ACEP
  • 2.  RE: Deploy RAP in L3 network environment
    MVP EXPERT
    Posted Jun 12, 2023 04:41 AM
    Any AP can be configured as a RAP, just some APs (such as the 505H) have a better form factor suited to being a RAP (e.g additional ports, desk stand etc).
    You have a few options depending on the firmware running on the AP and if the AP is in either CAP or RAP mode. Take a look at the WAN Link Failure for Campus APs or the Remote-AP Operation if using a RAP.
