Hi.
I'm pretty new to IMC, and trying to configure auto deployment.
Using IMC 7.3, trying to configure an Aruba 2530-8G.
Everything is working fine except one thing; when configuring snmpv3 users, somehow it messes up the auth- and priv-protocol.
My config-template contains the following:
snmpv3 user username auth sha key priv aes key
Still, when the deployment is complete and I do a show snmpv3 user the result is:
User Name Auth. Protocol Privacy Protocol
username None None
Needless to say I'm not getting any snmp-connectivity. However, if I run the same snmpv3 user config as a cli-script during the deployment (or manually after deployment) it works fine:
username SHA CFB AES-128
Any ideas what could be causing this?
#snmp
