Detailed exact dhcp option configuration for AP master discovery
This thread has been viewed 75 times
  • 1.  Detailed exact dhcp option configuration for AP master discovery
    Posted Jun 01, 2016 09:18 AM
    Hello
    what is the right dhcp configuration for AP master discovery?
    thanks
    Steffen
  • 2.  RE: Detailed exact dhcp option configuration for AP master discovery
    Posted Jun 01, 2016 09:20 AM
    DHCP Option 43 = <controller-ip>
    DHCP Option 60 = ArubaAP
  • 3.  RE: Detailed exact dhcp option configuration for AP master discovery
    Posted Jun 01, 2016 09:27 AM
    You ask for "detailed", but don't say what DHCP server.
    In general, the following should be configured:
    • DHCP Option 43 =  <IP of Controller>
    • DHCP Option 60 = ArubaAP
    Details fo different DHCP Servers:
  • 4.  RE: Detailed exact dhcp option configuration for AP master discovery
    Posted Jun 01, 2016 11:30 AM
    Thanks for the fast reply.
    as i understand is the following correct?:
    - the DHCP server receives the AP's DHCP request
    - in this request is an Option 60 with value ArubaAP
    - with this, the DHCP Server can filter this request and send a defined Option 43, which is configured in this filter
    is this all, or must the DHCP Server sends the Option 60 back to the Access Point?
    And when yes, is the question for what i must do this?
    Steffen
  • 5.  RE: Detailed exact dhcp option configuration for AP master discovery
    Posted Jun 05, 2016 12:01 PM
    Steffen
    Hi Steffen,
    Just trying to save you some time and frustration from our own personal experience - hence the importance of clembo's question about the DHCP Server Type/Vendor. We had spent several days of research (looking into 3 year old posts - Adonis BlueCat DHCP Option 43 for Aruba AP's) and working with Aruba TAC to figure out DHCP Option 43. We were able to get DHCP Option 43 working after reaching out to BlueCat Support - who actually had pre-made instructions for us. :-) - which also led to marking the earlier mentioned 3 year old post as solved.
    I believe your understanding of the steps for DHCP Option 43 is correct. In regards to Option 60 being sent back to the AP - I suspect this is necessary as packet captures of our "Successful Implementation" of Option 43, as well as Aruba's KB Article Packet Capture show Option 43 AND Option 60 both being included in the DHCP Offer to the AP.
  • 6.  RE: Detailed exact dhcp option configuration for AP master discovery
    Posted May 16, 2018 12:30 PM
    do you have specific instructions for Mikrotik?
    We are using Mikrotik RouterOS v6.40.5 for DHCP Server
    In Mikrotik there are options I'm not sure what Aruba nrequires..
    The Mikrotik Wiki supplies the following information regarding DHCP value types :
    • 0xXXXX - hex string (works also in v5)
    • 'XXXXX' - string (works also in v5 but without ' ' around the text)
    • $(XXXXX) - variable (currently there are no variables for server)
    • '10.10.10.10' - IP address
    • s'10.10.10.10' - IP address converted to string
    • '10' - decimal number
    • s'10' - decimal number converted to string
    Thanks!
  • 7.  RE: Detailed exact dhcp option configuration for AP master discovery
    Posted May 17, 2018 10:10 AM
    Thanks!
    I haven't seen instructions specific to Mikrotek. A packet capture of the DHCP offer would be helpful to confirm, but I would suspect the IP address response to be fine. Also, DHCP option 60 needs to be in the offer as well.
  • 8.  RE: Detailed exact dhcp option configuration for AP master discovery
    Posted Nov 13, 2018 05:05 AM
    Which is the right syntax on Linux server from below options. Please confirm.
    option arubaap.serverip = "100.98.193.6";
    or
    option arubaap.serverip 146.250.59.20 ;  >>> can we have a space after IP? Is there an issue if we leave a space?
    or
    option arubaap.serverip 100.100.224.134;
  • 9.  RE: Detailed exact dhcp option configuration for AP master discovery
  • 10.  RE: Detailed exact dhcp option configuration for AP master discovery
    Posted Jun 04, 2016 10:43 PM
    Hi Steffen, As clembo said, what's the DHCP Server? Is it Adonis Blue Cat, Windows Server, etc?
    #AirheadsMobile
