Developer
devHub Aruba Central 'Try it' Feature
  • 1.  devHub Aruba Central 'Try it' Feature
    Posted 14 days ago
    Hi folks!
    The Automation team is thrilled to announce a significant enhancement for our Central customers. HPE Aruba Networking Central users can now make API calls directly from our API Reference Guide on devHub to their selected Central instance.
    This feature is designed to streamline your development process, making it more efficient than ever to learn & use Central REST APIs in your automation projects. Here is how you can get started with this feature -
    1. Enter your Central Access Token in the Authorization field. You can find steps to create an access token here.
    2. Select your Central Account's API BaseURL from the dropdown. You can find the list of Central API Gateway URLs here.
    3. Click on 'Try It' button to make the Central API call
    Check out the screenshots/GIFs for more details and dive into the improved API Reference Guide today. Happy Automating!
    Add Access Token to the Authorization field
    Select a Central API BaseURL from Dropdown
  • 2.  RE: devHub Aruba Central 'Try it' Feature
    Posted 14 days ago
    What a great feature to have. Many thx to Dev team to enable this.
    Best, Gorazd
    Gorazd Kikelj
    MVP Expert 2023
