device access AAA is there any possible to authenticate Avaya switch 7200 serial thru radius service
  • 1.  device access AAA is there any possible to authenticate Avaya switch 7200 serial thru radius service
    Posted Jun 26, 2017 10:40 AM
    I have  a bunch of Avaya switch 7200  serial , so far I can successfully implement Tacacs+ service for access authen thru CMPP. but following the design, I have to use Radius for those devices access auth.
    I tried enable radius-notel, but it seems the authencation request is accepted by CMPP and authentication is successfully, but still failed to login the avaya devices.
    Such as access-priority  from none to rwa , there should be 6 levels for avaya switch, and vender code 1584. But I couldn't find those attribute from Radius-nortel
    thank you
  • 2.  RE: device access AAA is there any possible to authenticate Avaya switch 7200 serial thru radius service
    Posted Jun 19, 2018 02:47 PM
    Don't know if this is still relevant but I ran into this same issue some time ago.
    You need to return the correct user priviledge to the VSP7200 switch.
    The vendor you need to use is "Bay-networks".
    See attached screenshots for correct radius attributes.
    Micky
