Device connected but can't pass traffic
  • 1.  Device connected but can't pass traffic
    Posted Apr 29, 2013 01:50 PM
    I saw last week two cases of devices connected to the wifi network but can't communicate and on the taskbar it says limited connection.
    When I checked the ip address information on the device all is correct (ip/netmask/gateway,dns) but on the user table on the controller the same ip address is already used by an other device with different mac address and the age time is more than 24h. I deleted the old user on the controller and the device started passing traffic.
    So, the issue is the user is not deleted from the user table on the controller when the entry is outdated. On the controllers, I can see many entries like that, I guess all the devices connected with those ip addresses are not able to pass traffic.
    Is there any way to flush the user table of those aged entries like the dhcp does?
    Thanks.
  • 2.  RE: Device connected but can't pass traffic
    Posted Apr 29, 2013 01:55 PM
    What code are you running ?
    What AP is the device connected to ?
    Is it only happening to one particular device or several?
  • 3.  RE: Device connected but can't pass traffic
    Posted Apr 29, 2013 02:11 PM
    Sorry, the code is 6.1.2.4 and the APs are 105.
    The two cases i mentioned were on two different devices (W7 and Chrome OS).
    Thanks.
  • 4.  RE: Device connected but can't pass traffic
    Posted Apr 29, 2013 03:07 PM
    Do you use VLAN pooling ? if you do how do you have it set it up? Even or Hash?
  • 5.  RE: Device connected but can't pass traffic
    Posted Apr 29, 2013 03:25 PM
    Also are you doing IP Mobility between controllers ?
  • 6.  RE: Device connected but can't pass traffic
    Posted Apr 29, 2013 04:05 PM
    No.
  • 7.  RE: Device connected but can't pass traffic
    Posted Apr 29, 2013 05:15 PM
    Have you changed the idle timeout settings ?
    do a show aaa timers
    And if you haven't I think you should open a TAC case
  • 8.  RE: Device connected but can't pass traffic
    Posted Apr 30, 2013 09:54 AM
    Hi Victor,
    I did not change the timers.
    (wifi_master) #show aaa timers
    User idle timeout = 1800 seconds
    Auth Server dead time = 10 minutes
    Logon user lifetime = 5 minutes
    User Interim stats frequency = 300 seconds
    I am planning to upgrade to 6.1.3.6-AirGroup to integrate AirGroup in our environment. If the issue is not resolved with the new AOS, i will open a TAC case.
    Thanks a lot for your help.
  • 9.  RE: Device connected but can't pass traffic
    Posted Apr 29, 2013 03:44 PM
    Yes, we are using VLAN pooling. It should be Hash because we are running 6.1.2.4.
    Thanks.
  • 10.  RE: Device connected but can't pass traffic
    Posted Apr 30, 2013 10:21 AM
    @Mario12 wrote:
    Thanks.
    Mario,
    Please use AAA fast age to age out those entries:
    http://community.arubanetworks.com/t5/Command-of-the-Day/COTD-aaa-user-fast-age/td-p/4098
  • 11.  RE: Device connected but can't pass traffic
    Posted Apr 30, 2013 02:51 PM
    Hi Joseph,
    Thanks, I will try that and come back to you on this.
  • 12.  RE: Device connected but can't pass traffic
    Posted Apr 30, 2013 05:14 PM
    Hi Joseph,
    we did not have duplicate sessions.
    we have only one entry in the Aruba user-table with the same ip address that is issued by dhcp to the client, but the mac address in the Aruba user table is different from the client mac address.
    Please see included file.
  • 13.  RE: Device connected but can't pass traffic
    Posted Oct 23, 2013 11:29 AM
    I'm having the same exact issue on 6.1.2.4.  Did you ever resolve this?
    Dave
  • 14.  RE: Device connected but can't pass traffic
    Posted Nov 19, 2013 03:20 PM
    Hi - I have the same issue. Been having for the past few releases. Currently on 6.1.3.6-AirGroup.
    Any update would be appreciated!
  • 15.  RE: Device connected but can't pass traffic
    Posted Nov 19, 2013 03:25 PM
    Hi Burbackm,
    For us, it turned out to be a bug with the broadcast-filter-arp option in the stateful firewall.  We disabled the option on the stateful firewall and enabled it at the VAP level and didn't have anymore issues.
    I hope this helps!
    Dave
  • 16.  RE: Device connected but can't pass traffic
    Posted Nov 19, 2013 03:28 PM
    Hi Dave -
    We've had broadcast-filter ARP turned off, so I don't think that's the issue in my case. Thanks, though.
    Mike
