Wired Intelligent Edge
Device fingerprimting stopped working
This thread has been viewed 16 times
  • 1.  Device fingerprimting stopped working
    MVP EXPERT
    Posted May 06, 2022 05:28 AM
    Hi
    I have a number of 2930 switches ( WC.16.10.18)  configured  to  implement device fingerprinting. I have this running in a home ( baby switch WC 16.11.4)  where it just works through reboots and all.
    Just logged onto my work switches ( uptime 50 days ... and show device-fingerprinting client-details shows ......  nothing , no client details at all. nothing in log files to indicate device fingerprinting is happening at all .
    Short of rebooting switch ( cant do that without a lot of pain) any idea what i can do to start this. ?
    It's not just 1 switch, its all of them configured to implement device fingerprinting
    Have enabled lldp,cdp,http,dhcp
    would expect to see windows devices, aruba APs  and a few other stuff
    dhcp-snoop  works just fine so can see mac addresses / ip addresses on a switch port
    A
    Alex Sharaz
  • 2.  RE: Device fingerprimting stopped working
    Posted May 06, 2022 06:57 AM
    Hi Alex,
    You can try to flap a port, where DFP is applied and check the status with "show device-fingerprinting client-status". What is the status for this port?
    I am pretty sure you got the DFP technical whitepaper document. Did you go through the troubleshooting steps described there?
    Stanislav Naydenov
  • 3.  RE: Device fingerprimting stopped working
    MVP EXPERT
    Posted May 06, 2022 07:27 AM
    Fingerprints seem to have come back, read somewhere that they are cleared off switch every 30 mins, just logged onto switches and fingerprints back
    A
  • 4.  RE: Device fingerprimting stopped working
    MVP EXPERT
    Posted May 06, 2022 07:24 AM
    Crisis over, just logged onto switches and all the fngerprints have appeared again.  Just read that the fingerprints     are only held on the  switch for 30 mins, so  guess i hit the period bewteen them being deleted and recreated
    A
    Alex Sharaz
  • 5.  RE: Device fingerprimting stopped working
    Posted May 06, 2022 07:42 AM
    Hi Alex,
    yes, that's correct (details are removed after 30 minutes). Good that you have clarified the situation already.
    Stanislav Naydenov
