Network Management
Device not getting dhcp or network from trunk
This thread has been viewed 33 times
  • 1.  Device not getting dhcp or network from trunk
    Posted Mar 12, 2024 02:29 PM
    This is my first time creating a VLAN interface on the Watchguard. But I have have interface 2 as type VLAN, and then I have a VLAN "Bechdon VLAN" associated with interface 2. Below are also my network and VLAN settings.
    VLAN is set to Tagged on watchguard. Then I have a cable connecting from interface 2 on WG to interface 17 on an Aruba switch Tagged VLAN 6. Then if I assign interface 18 on the same Aruba switch as Untagged VLAN 6, I get a DHCP address like I'm supposed to.  We have another building, then I already have existing networks already there which I setup. So just like all the existing network, I have interface 25 on the switch Tagged VLAN 6 among the existing ones, then on the switch at new building Tagged VLAN 6 on the uplink port.
    This is where the problem and confusion is. When I assign a port on the switch at new building Untagged VLAN 6, I don't get an IP address, and even if I setup a static IP on the "Bechdon VLAN", I can't ping anything. I have VLAN 6 on all the switches, so its not because its missing VLAN 6.
    What am I doing wrong?  All my switches are Aruba.
    This is my configuration.
    Interface 2 on Watchguard VLAN 6 (Tagged) to interface 17 (Tagged VLAN 6) on Aruba switch.  Interface 18 (Untagged VLAN 6), I get an IP address on VLAN 6.
    Interface 25 on the same switch as above (Tagged VLAN 6) to interface 49 (Tagged VLAN 6) on the new building switch.  Interfaces 25/49 are my existing uplink ports for other networks also, and these are working fine.
    Then interface (Unagged VLAN 6) on a port on the new building switch, the laptop doesn't get a DHCP.
  • 2.  RE: Device not getting dhcp or network from trunk
    Posted Mar 12, 2024 02:36 PM
    This is the port setting on my switch unlinking from WatchGuard interface 2 (VLAN 6 Tagged).  If I plug in a laptop on port 18, the laptop gets connection to VLAN 6.  Also, I'm testing on both switches with the same laptop and Ethernet cable.  I also tried a different port on the new switch Untagged VLAN 6, and I still don't get an IP address.
    Core-24-lower# sh vlans
     Status and Counters - VLAN Information
      Maximum VLANs to support : 256
      Primary VLAN : DEFAULT_VLAN
      Management VLAN :
      VLAN ID Name                             | Status     Voice Jumbo
      1       DEFAULT_VLAN                     | Port-based No    No
      4       CNC WiFi                         | Port-based No    No
      5       CMM                              | Port-based No    No
      6       Bechdon                          | Port-based No    No
      100     voice                            | Port-based Yes   No
      302     wireless                         | Port-based No    No
    Running configuration:
    interface 17
       name "Bechdon VLAN Uplink"
       tagged vlan 6
       exit
    interface 18
       name "Bechdon Test Port"
       untagged vlan 6
       exit
    interface 25
       name "Uplink to new bldg"
       tagged vlan 1,4-6,100,302
       exit
    This is the switch at new building.  If I plug in a laptop on port 15, the laptop gets no connection to VLAN 6.
    Newbldg-Core# sh vlans
      Management VLAN :
      4       CNC Wireless                     | Port-based No    No
      100     Voice                            | Port-based Yes   No
      302     Wireless                         | Port-based No    No
    interface 15
       name "Steve"
       untagged vlan 6
       exit
    interface 49
       name "Uplink"
       exit
  • 3.  RE: Device not getting dhcp or network from trunk
    Posted Mar 12, 2024 03:30 PM
    A good place to start troubleshooting maybe to look for MAC addresses on both switches.
    Run a "show mac-address vlan 6" on both switches, compare the tables - specifically look to see if your downstream laptop MAC addresses are populating on your Core.
    Run a "show lldp info remote-device" to ensure you have the switches and interfaces correct - also to be sure you didn't miss any aggregation switches.
    If my post was useful, please Accept Solution and Give Kudos.
    Zak Chalupka
    Principal Engineer - HPE Aruba
    ACDX | ACMP | ACSP | ACCP
    wifizak@hpe.com
    Ideas expressed here are solely my own and not necessarily that of HPE Aruba.
  • 4.  RE: Device not getting dhcp or network from trunk
    Posted Mar 12, 2024 03:41 PM
    Thank you, I ran the first command, and I see interface 17 for VLAN 6, but nothing on the new building switch for VLAN 6.
    'Core-24-lower' It should be showing Port 25 since that's my uplink to the other switch.
    Core-24-lower# sh mac-address vlan 6
     Status and Counters - Address Table - VLAN 6
      MAC Address       Port
      00005e-000134     17
    Newbldg-Core# sh mac-address vlan 6
      MAC Address       Port
  • 5.  RE: Device not getting dhcp or network from trunk
    Posted Mar 12, 2024 03:49 PM
    If you look at LLDP does everything line up? Anything missing or labeled?
    Based on your config snippets the tags should be all you need. Do you have Spanning Tree enabled? Not that you need to necessarily, but it could be something getting in the way.
    Zak Chalupka
    wifizak@hpe.com
  • 6.  RE: Device not getting dhcp or network from trunk
    Posted Mar 13, 2024 09:45 AM
    Thank you.  It turned out to be something silly on my part :)
    I mislabeled the port and I was tagging VLAN 6 to the wrong one.
    But after double checking the using the sh lldp ... command, and sh mac-add | in .., I figured out the right uplink port, and everything works now.
  • 7.  RE: Device not getting dhcp or network from trunk
    Posted Mar 13, 2024 10:08 AM
    Glad those commands helped!
    Zak Chalupka
    wifizak@hpe.com
  • 8.  RE: Device not getting dhcp or network from trunk
    Posted Mar 13, 2024 08:15 AM
    Hi
    maybe check a little more :
    on Core :
    show mac-addr 25
    show interface brief 25
    show vlan port 25
    show vlan 6
    show spanning-tree
    show spanning-tree 25 detail
    On NewBldg :
    show mac-addr 49
    show interface brief 49
    show vlan port 49
    show vlan 6
    show spanning-tree
    show spanning-tree 49 detail
    Any loop-protect function activated ?
    Frederic
    (kudos welcome)
