Wired Intelligent Edge
Device-Profiling - Access Points
This thread has been viewed 35 times
  • 1.  Device-Profiling - Access Points
    Posted Jul 19, 2022 09:12 AM
    We are in the testing stages of replacing our soon to be EOL 215 series access points with the new 635 series. These 2 models are incompatible due to firmware versions and need to be on separate vlans for their controllers to work correctly.
    Our access switches are configured to profile AP devices and give them the correct VLAN information. Where I am getting stuck is that the new APs keep getting placed into the profile for old APs. I've matched the OUI for the profile to what wireshark's lookup tool says for the OUI based on the mac address of the new APs. However, the OUI in use for the older APs does not match the start of the mac address as wireshark claims it should. So I'm guessing that the OUI of 000b86 is some kind of aruba catch-all or parent oui. Curiously even if I disable the profile for the OUI used for old APs, the new AP still is not profiled by the OUI of 946424.
    I'm sure this is something simple where I'm missing some small but key piece of information. Obviously, I can always just change the vlan config on the profile for the OLD AP model and just roll from there since it is catching the new APs. But I would like to be able to have both models profiled correctly to make the deployment of 100+ access points simpler by not having to ensure every AP connected to a switch gets swapped at the same time simply because of a minor config hurdle.
    Old device identity ap215
    device-identity name "ap"
    lldp oui 000b86
    exit
    New device identity ap635
    device-identity name "AP635"
    lldp oui 946424
    exit
    Old device profile ap215
    device-profile name "AP-Profile"
    untagged-vlan 450
    tagged-vlan 202-203,205
    exit
    New device profile ap635
    device-profile name "AP635-Profile"
    untagged-vlan 200
    exit
    device-profile device-type "ap"
    associate "AP-Profile"
    enable
    exit
    device-profile device-type "AP635"
    associate "AP635-Profile"
    enable
    exit
    New AP635 LLDP Info
    Aruba2930F# show lldp info remote-device 18
    LLDP Remote Device Information Detail
    Local Port : 18
    ChassisType : mac-address
    ChassisId : 946424-c447bb
    PortType : mac-address
    PortId : 94 64 24 c4 47 bb
    SysName : 94:64:24:c4:47:bb
    System Descr : ArubaOS (MODEL: 635), Version Aruba IAP
    PortDescr : eth0
    Pvid :
    System Capabilities Supported : bridge, wlan-access-point
    System Capabilities Enabled : wlan-access-point
    Old AP215 LLDP Info
    Aruba2930F# show lldp info remote-device 47
    Local Port : 47
    ChassisId : f05c19-111111
    PortId : f0 5c 19 11 11 11
    SysName : f0:5c:19:11:11:11
    System Descr : ArubaOS (MODEL: 215), Version Aruba IAP
    PortDescr : bond0
    Pvid :
  • 2.  RE: Device-Profiling - Access Points
    Posted Jul 20, 2022 04:16 AM
    It depends on the OS type. ie, 2930 AOS, or 6300 AOS-CX.
    This is the configurations I am using, and it is working fine.
    (However only on single interfaces, when enabling dual interfaces on AP's with LACP it is not,
    [then you must set the vlan on the LACP trunk, untagged])
    AOS
    device-profile name "default-ap-profile"
       untagged-vlan 11
       allow-jumbo-frames
       no allow-tunneled-node
       poe-priority low
       exit
    device-profile type "aruba-ap"
       enable
       exit
    CX:
    port-access lldp-group Aruba-AP_LLDP
         seq 20 match sys-desc ArubaOS
    port-access role Aruba-AP
        description Aruba AP
        mtu 9198
        poe-priority low
        trust-mode dscp
        vlan access 11
    port-access device-profile default-ap-profile
        enable
        associate role Aruba-AP
        associate lldp-group Aruba-AP_LLDP
     Hope this helps
  • 3.  RE: Device-Profiling - Access Points
    Posted Jul 20, 2022 04:30 AM
    The LLDP OUI is NOT the first part of a MAC address it is instead an OUI in the vendor specific LLDP TLV and for all Aruba APs the same. Therefore you cannot use it to differentiate between different models of Aruba APs.
    LLDP OUI example of Aruba APs
    You may use the LLDP System Description or System Name for your use case which is supported from AOS-S  version 16.10.0003 for the 2930 switch series.
  • 4.  RE: Device-Profiling - Access Points
    Posted Jul 20, 2022 12:45 PM
    Thanks for this, explains a lot. Mildly concerning that my Aruba Sales Engineer gave me the wrong information on this and I spent a day beating my head against a wall because of it.
