Device requires a static IP, but cant get it to work
  • 1.  Device requires a static IP, but cant get it to work
    Posted Sep 25, 2014 07:56 AM
    We have a system that uses a wifi bridge to connect, but it doesnt support DHCP, and putting a static address in doesnt work either.  The ssid its connecting to has 2 vlans (pooled) associated with it, and I have tried an IP from both associated lease lease pools, assuming that aruba could be dropping the device onto the other vlan, but it simply wont work.
    Any ideas??  Im tempted to dell the system engineer to get a bridge that supports dhcp, as it is an old legacy system!
    Cheers
  • 2.  RE: Device requires a static IP, but cant get it to work
    Posted Sep 25, 2014 07:57 AM
    Do you have enforce DHCP enabled in your AAA profile?
  • 3.  RE: Device requires a static IP, but cant get it to work
    Posted Sep 25, 2014 07:59 AM
    Wasnt something Id manually changed, but seems disabled by default anyway.
    Cheers
  • 4.  RE: Device requires a static IP, but cant get it to work
    Posted Sep 25, 2014 08:01 AM
    Please try using a user derivation rule to manually set the VLAN.
  • 5.  RE: Device requires a static IP, but cant get it to work
    Posted Sep 25, 2014 08:03 AM
    That was actually the next thing I was going to try, I was just hoping that if we tried an address from each vlan, that it would work anyway...
