Device Setup --> Communication --> Default Credentials
  • 1.  Device Setup --> Communication --> Default Credentials
    Posted Jun 12, 2013 08:56 AM
    Is there a way to add/remove entries from the Default Credential screen?  I would like to narrow down the list to only device types I am monitoring with AirWave.
    I am running AMP version 7.5.4.
  • 2.  RE: Device Setup --> Communication --> Default Credentials
    Posted Jun 12, 2013 10:27 AM
    The list on the Device Setup -> Communications page has generally default credentials for each vendor.  There's no harm in them being there as these credentials are only used if you are doing 'auto-authorization' of your devices.  If you're adding all devices manually, then there's no problem.  Otherwise it'd be a feature request to restrict the lists to only devices that you have (or devices you plan to have) in your network.
  • 3.  RE: Device Setup --> Communication --> Default Credentials
    Posted Jun 12, 2013 11:20 AM
    Thanks for the reply Rob.  So the only way to trim this list back is by putting in a feature request with TAC?
  • 4.  RE: Device Setup --> Communication --> Default Credentials
    Posted Jun 12, 2013 11:25 AM
    Yeah, the list on Device Setup -> Communications is currently not editable, though after initial configuration - most users don't revisit that page.  The page you'll most likely be on more frequently would be the Group -> select group -> Basic page, and that one can be narrowed down to just 'devices on the AMP' or 'devices in the group'.  It's going to be a feature request to change the Communications page which will depend on Product Management decision based on the feature request and upvotes on that request.
  • 5.  RE: Device Setup --> Communication --> Default Credentials
    Posted Jun 12, 2013 11:28 AM
    Okay, thanks for you responses.
