Device traffic class=voice VSA on aruba switch?
  • 1.  Device traffic class=voice VSA on aruba switch?
    Posted Dec 24, 2018 11:58 AM
    Does anybody knows if it is supported?
    I used to use that attribute for voip vlans on comware v7. Is there any alternative in aruba?
    Using 16.6 2930M.
  • 2.  RE: Device traffic class=voice VSA on aruba switch?
    Posted Dec 24, 2018 12:05 PM
    No, you just use a voice user role. Take a look at the ClearPass Solution Guide for Wired Policy Enforcement.
  • 3.  RE: Device traffic class=voice VSA on aruba switch?
    Posted Dec 24, 2018 12:21 PM
    Thanks Tim, i did find your guide very helpful!
    Just thought i could make my switch config a bit lighter :)
  • 4.  RE: Device traffic class=voice VSA on aruba switch?
    Posted Dec 24, 2018 12:24 PM
    You can use downloadable user roles with very little switch config.
  • 5.  RE: Device traffic class=voice VSA on aruba switch?
    Posted Dec 24, 2018 12:32 PM
    I do use them for my other profiles.
    But with the voice vlans that would be a waste.
    Since i have multiple sites its better to have single rule for all phones to grant voice traffic predefind user-rule (just a vlan).
    With comware it was super easy since voice vlan + traffic class VSA sent from CPPM did all the trick.
    To be honest Aruba switches does have overall config much lighter the comware.
  • 6.  RE: Device traffic class=voice VSA on aruba switch?
    Posted Dec 24, 2018 12:34 PM
    Use a VLAN name. This makes the ClearPass policy decoupled from the switch VLANs.
  • 7.  RE: Device traffic class=voice VSA on aruba switch?
    Posted Dec 24, 2018 12:37 PM
    Oh right!
    How i didn't thought of that?
    Thanks! that will do the job a lot more easier.
