Network Management
Devices Mismatched
This thread has been viewed 26 times
  • 1.  Devices Mismatched
    Posted Dec 02, 2021 01:21 PM
    Dears,
               I have airwave server and aruba switches 2930m all switches are stacked in four floor, but some floors have a missing switch stack that powered off because no need to it , all switches have a full stack correctly appears on airwave as a (good configuration) but the missing stack switch appear (Mismatched),
    is the missing stack is a problem to appear the switch on airwave as a mismatched configuration??
    Mohamed Amin
  • 2.  RE: Devices Mismatched
    MVP EXPERT
    Posted Dec 02, 2021 05:33 PM
    Mismatch means that the current switch configuration mismatch the baseline in airwave. you could create a new baseline of your current configuration
    Marcel Koedijk | MVP Guru 2021 | ACEP | ACMP | ACCP | ACDP | Ekahau ECSE | Not an HPE Employee | Opionions are my own
  • 3.  RE: Devices Mismatched
    Posted Dec 05, 2021 04:36 AM
    On airwave version 8.2.4.2 i didn't fine the baseline configuration, the tab of backup configuration from the switches and i can't make configuration job, could you please tell me how to solve this issue
    Mohamed Amin
  • 4.  RE: Devices Mismatched
    MVP EXPERT
    Posted Dec 05, 2021 08:57 AM
    8.2.4.x is end of support december 2019
    Outlook voor iOS downloaden
  • 5.  RE: Devices Mismatched
    Posted Dec 05, 2021 01:50 PM
    Okay,Thanks
    but i need to know that i didn't find the button of backup , i can't run configuration job and i didn't find the baseline configuration , Is all issues from the version 8.2.4.x ? or it's missing configuration from my side ?
    Mohamed Amin
  • 6.  RE: Devices Mismatched
    MVP EXPERT
    Posted Dec 05, 2021 04:34 PM
    I don't run airwave in my homelab at the moment, so I can't show you.
    Maybe this topic helps you: https://blogs.arubanetworks.com/solutions/say-goodbye-to-airwave-mismatches/
  • 7.  RE: Devices Mismatched
    Posted Dec 16, 2021 09:02 AM
    under Groups>Basic page we have option to set Audit option, if you dont see this please upgrade server to latest code, we have done lot of enhancement related to switch monitoring/management.
    If switch is in monitor only mode we can import latest template from switch from Groups> Templates page.
    Pavan Arshewar
    Principal Network Engineer
    If my post addresses your query, give kudos!
