Best to work with Aruba Support. It can be that some process is in debug mode/state and filling up the disk.
Original Message:
Sent: Oct 03, 2023 11:32 PM
Subject: /dev/mapper/vg_system-lv_var_log out of space
Dear Sir,
Sometimes our Airwave server not function well, we checked from CLI, the root cause is the disk space ( /dev/mapper/vg_system-lv_var_log ) run out of space and we need to execute cleanup to resolve the issue temporary. the df -h information after execute cleanup command :
Could you please mention me the other solution not only execute cleanup periodically?
$ df -h
Filesystem Size Used Avail Use% Mounted on
devtmpfs 48G 0 48G 0% /dev
tmpfs 48G 3.2M 48G 1% /dev/shm
tmpfs 48G 19M 48G 1% /run
tmpfs 48G 0 48G 0% /sys/fs/cgroup
/dev/mapper/vg_system-lv_root 10G 3.0G 7.1G 30% /
/dev/sda2 488M 115M 338M 26% /boot
/dev/sda3 256M 12M 245M 5% /boot/efi
/dev/mapper/vg_system-lv_tmp 10G 787M 9.3G 8% /tmp
/dev/mapper/vg_system-lv_home 5.0G 33M 5.0G 1% /home
/dev/mapper/vg_system-lv_var 795G 123G 673G 16% /var
/dev/mapper/vg_system-lv_var_log 20G 20G 531M 98% /var/log
/dev/mapper/vg_system-lv_var_log_audit 5.0G 48M 5.0G 1% /var/log/audit
tmpfs 64M 0 64M 0% /var/lib/pgsql/pg_stats_temp
tmpfs 9.5G 0 9.5G 0% /run/user/1001
tmpfs 9.5G 0 9.5G 0% /run/user/995
tmpfs 9.5G 0 9.5G 0% /run/user/0
tmpfs 9.5G 0 9.5G 0% /run/user/994
Jackson Ku
