last person joined: 3 hours ago
DFS Support for AP-11x Series
  • 1.  DFS Support for AP-11x Series
    Posted May 23, 2014 12:55 PM
    What's the status of DFS on Instant AP-114/115?
    #ALE
  • 2.  RE: DFS Support for AP-11x Series
    Posted May 23, 2014 04:47 PM
    It should be supported.  It is listed on the product Spec sheet:  http://www.arubanetworks.com/products/access-points/110-series/
  • 3.  RE: DFS Support for AP-11x Series
    Posted May 26, 2014 11:35 AM
    I just deployed two IAP-115 units and did not see the DFS channels listed in the available channels configuration.
    There was no change after an update to the latest firmware.
  • 4.  RE: DFS Support for AP-11x Series
    Posted May 28, 2014 10:06 AM
    Just confirmed with Product Management that the HW is certified for DFS; however, the SW support did not make it into AOS 6.3.  It will appear in 6.4.1 which is due right around the corner.  I don't have confirmation yet on when it is due in IAP but will be after the AOS 6.4.1 release.
