Aruba Central
DHCP
This thread has been viewed 30 times
  • 1.  DHCP
    Posted Nov 02, 2022 07:15 AM
    Hi!
    Is this ok, to have so many and often client DHCP acknowledged events?
    Thanks!
  • 2.  RE: DHCP
    MVP GURU
    Posted Nov 02, 2022 07:38 AM
    Depending on the number of clients, and the lease time of the DHCP scope, totally normal. The ACK is the last part of the DHCP lease procedure.
    Dustin Burns
    ACCX 1271| ACMX 509| ACSP | ACDA | MVP Guru 2022
  • 3.  RE: DHCP
    Posted Nov 02, 2022 07:46 AM
    in the picture below are events related only to one client and DHCP lease time is set to 2 hours. And these DHCP acknowledgments happen randomly but very often, for instance every minute then maybe three minutes later then twenty minutes later.
  • 4.  RE: DHCP
    Posted Nov 08, 2022 06:10 AM
    Clients may do another DHCP after a roam, if that explains what you see. But the event is 'green' and an 'in general good' and expected thing.
