DHCP
  • 1.  DHCP
    Posted Oct 22, 2012 11:40 AM
    Looking at the logs i found this:
    Oct 22 10:33:25  dhcpdwrap[1820]: <202085> <DBUG> |dhcpdwrap|  No arp entry for ip address 137.52.242.221 eth1.1242
    I thought the router is the one keeping the arp table whey does the wireless controller shows this error?
    Thank you,
    Enrique.
  • 2.  RE: DHCP
    Posted Oct 22, 2012 12:22 PM
    The controller has a ARP table. :)
    #show arp
    That will show you the ARP table.
    Every device with an IP with have an ARP cache of some sort.
    I'm not sure on the error though. What device is that IP assigned to?
    Cheers
    James
  • 3.  RE: DHCP
    Posted Feb 12, 2013 08:29 AM
    I'm having this exact same issue. Any resolution?
  • 4.  RE: DHCP
    Posted Feb 20, 2013 01:10 PM
    do you actually have an issue, or is the issue only this mesage? could very well be something totally harmless.
    you might want to open a case or share more information here so someone might help you out. first thing that comes to mind, do you recognize the IP, is it in your client subnet, controller, ....
