Wired Intelligent Edge
DHCP at Switch 8320
This thread has been viewed 60 times
  • 1.  DHCP at Switch 8320
    Posted Mar 06, 2021 09:00 AM
    Hello guys again i'm now at new case
    i have switch 8320 with vlans
    now i need to make DHCP at vlan 10
    ip address 192.168.3.1/24
    gateway 192.168.3.2
    how i can make this config
    thanks guys
    Ahmed Fares
  • 2.  RE: DHCP at Switch 8320
    MVP GURU
    Posted Mar 06, 2021 12:21 PM
    config t
    vlan 10
       name vlan-10
       exit
    interface vlan 10
       ip address 192.168.3.2/24
       exit
    dhcp-server vrf default
       authoritative
       pool vlan-10
          default-router 192.168.3.2
          range 192.168.3.10 192.168.3.254
          dns-server 8.8.8.8 8.8.4.4
          domain-name burns.lab
          lease 01:00:00
          exit
       enable
       end
    Dustin Burns
  • 3.  RE: DHCP at Switch 8320
    Posted Mar 06, 2021 12:34 PM
    thank you brother
    but are you sure this cli (dhcp-server vrf default) working with 8320
    i saw only dhcp-relay the only command under dhcp :(
    Ahmed Fares
  • 4.  RE: DHCP at Switch 8320
    MVP GURU
    Posted Mar 06, 2021 01:05 PM
    Can you show me what your seeing form the cli?
    Dustin Burns
  • 5.  RE: DHCP at Switch 8320
    MVP GURU
    Posted Mar 06, 2021 01:09 PM
    According to this, it looks like those models may only allow you to configure a DHCP relay address to forward the requests to....
    https://support.hpe.com/hpesc/public/docDisplay?docId=a00042840en_us&docLocale=en_US
    At least you have a CX template for DHCP now :)
    Dustin Burns
  • 6.  RE: DHCP at Switch 8320
    MVP GURU
    Posted Mar 06, 2021 01:44 PM
    Hello, can you tell us what ArubaOS-CX version your Aruba 8320 is currently running on?
  • 7.  RE: DHCP at Switch 8320
    Posted Mar 07, 2021 04:37 AM
    TL 10.02.00.20
    Ahmed Fares
  • 8.  RE: DHCP at Switch 8320
    MVP GURU
    Posted Mar 07, 2021 08:37 AM
    it is very old (and it is recommended to update)
    May be the DHCP server feature is not yet available with this release...
    ACEP / ACMX #107 / ACDX #1281
  • 9.  RE: DHCP at Switch 8320
    MVP GURU
    Posted Mar 07, 2021 11:00 AM
    Ah yes! 10.03.0001 introduced the DHCP server. It can be found in the enhancements section in release notes:
    https://support.hpe.com/hpesc/public/docDisplay?docId=a00098882en_us
    Dustin Burns
