Wired Intelligent Edge
DHCP-BOOTP on Aruba 6000?
  • 1.  DHCP-BOOTP on Aruba 6000?
    Posted Mar 15, 2023 05:39 AM
    Previously we used the 2530, now we have the 6000.
    In the 2530 we would use the webinterface -> interfaces -> vlans ->
    and enabled DHCP/Boop under the IP Config under each VLAN, so we could easily verify if DHCP correctly configured before connecting client devices.
    Now i can't seem to find this option on the 6000.
    After looking at the documentation  https://www.arubanetworks.com/techdocs/AOS-CX/10.10/PDF/cli_6000-6100.pdf
    I have found i can do this with the commands:
    interface vlan x
    ip dhcp
    but then i get a prompt: "ip dhcp" is supported only on default vlan (vlan1)
    So i suppose i can do it but only for 1 vlan at a time?
    So there is no way like there was previously to enable dhcp for all vlans on the switch and see if all VLANs can receive an IP?
    Arubanetworks remove preview
  • 2.  RE: DHCP-BOOTP on Aruba 6000?
    Posted Mar 15, 2023 12:12 PM
    That's correct - unfortunately you can configure dhcp for one SVI only. You can find this information on page 292 in the guide you shared.
