DHCP config help
  • 1.  DHCP config help
    Posted Jul 19, 2018 03:18 AM
    I have attached a sample lab setup diagram.
    Basically I am looking for help in configuring an external DHCP server on Windows Server for assigning IP's for corp (VLAN 2029) and guests (VLAN 2066). I wanted to know what is the best recommended option to configure this - on switch using DHCP forwarding or on controllers using DHCP helper or any other way? I would highly appreciate if someone can help configuring as well.
    Many thanks in advance.
  • 2.  RE: DHCP config help
    Posted Jul 19, 2018 05:51 AM
    Where is the L3 gateway for the vlan 2029 & 2066?
    If it is on the switch, setup the DHCP helper/forward on the switch.
    If is is on the controller, setup the DHCP helper/forward on the controller
    Basic: for a device to do DHCP helper/forward it needs a IP address in that VLAN to work. Also IP routing should work.
    Looking at your design I think that you to have the L3 gateway on the switch so setup DHCP helper/forward on the switch.
    Hope it helps.
  • 3.  RE: DHCP config help
    Posted Jul 19, 2018 06:58 AM
    Thanks Frank, yes it is the switch. Any chance you have any sample configuration which can be used??
  • 4.  RE: DHCP config help
    Posted Jul 19, 2018 07:48 AM
    If you share (in a PM) the current config, brand and model of switch I will share a sample config.
    @manish.modi
