DHCP Exclude Address' What Does this mean?
  • 1.  DHCP Exclude Address' What Does this mean?
    Posted Jun 24, 2022 02:32 PM
    Trying to configure a DHCP pool on a Instant Access point.  Want to exclude some IP addresses on either end of the block.  Am I not looking this the right way?  Seems simple enough, but to me the warning seems indecipherable.
  • 2.  RE: DHCP Exclude Address' What Does this mean?
    Posted Jun 25, 2022 06:15 PM
    Do you have a dhcp scope already defined?
  • 3.  RE: DHCP Exclude Address' What Does this mean?
    Posted Jun 27, 2022 04:52 PM
    Yes, thank you for responding.  172.22.201.0/24.  Those are my excluded addresses.  Just can't figure out what the programmers want in the fields?
  • 4.  RE: DHCP Exclude Address' What Does this mean?
    MVP EXPERT
    Posted Jun 27, 2022 05:02 PM
    Define your DHCP scope as 172.22.201.0-172.22.201.255 (Not as 172.22.201.1-172.22.201.254).
    Marcel Koedijk | MVP Expert 2022 | ACEP | ACMP | ACCP | ACDP | Ekahau ECSE | Not an HPE Employee | Opinions are my own
  • 5.  RE: DHCP Exclude Address' What Does this mean?
    Posted Jun 27, 2022 08:51 PM
    Thanks for the answer.  Very non intuitive.  I already define the block up above that entry.  The entry blocks kind of say excluded not inclusive.  I guess I must be thinking about it the opposite way.
