DHCP Fingerprint and PS3
  • 1.  DHCP Fingerprint and PS3
    Posted Jun 13, 2012 09:54 PM
    Hi all,
    I have a bunch of fingerprints working but can't seem to figure out why the PS3 won't fingerprint. I lifted the dhcp-option from the debug just like the guide said but still can't get the fingerprint to work. Anyone have a PS3 fingerprint that they can send along?
    Here is what I've been trying: debug first than the line in the dev rule:
    Jun 13 21:21:49 :202536:  <DBUG> |dhcpdwrap| |dhcp| Datapath vlan986: REQUEST 28:0d:fc:70:5f:e0 reqIP=10.24.4.28 Options 36:0a01ff15 37:01030f06 3d:01280dfc705fe0 3c:50533300
    set role condition dhcp-option starts-with "01030f06" set-value xxx-wifixxx-mobile description "Playstation"
  • 2.  RE: DHCP Fingerprint and PS3
    Posted Jun 14, 2012 03:07 AM
    @bhubert wrote:
    Hi all,
    In that case, your "starts-with" would be "3701030f06".  You have to remove the colon and concatenate (combine) the 37 with the rest of the string.
  • 3.  RE: DHCP Fingerprint and PS3
    Posted Dec 19, 2012 11:36 AM
    I lifted the same fingerprint for PS3 and I cannot get it to work either. I'm still using MAC OUIs for the time being.
    My XBOX fingerprint is working great (370103060f).
  • 4.  RE: DHCP Fingerprint and PS3
    Posted Dec 19, 2012 11:54 AM
    Tim,
    What did you observe for the PS3 Fingerprint?
  • 5.  RE: DHCP Fingerprint and PS3
    Posted Dec 19, 2012 12:13 PM
    When I look in the controller under Authentication > User Rules, that dhcp-option rule has 0 hits and the mac address rules have quite a few. The dhcp-option rule is at the top of the list.
  • 6.  RE: DHCP Fingerprint and PS3
    Posted Dec 19, 2012 12:15 PM
    I meant, how did you discover the DHCP fingerprint for the PS3?
  • 7.  RE: DHCP Fingerprint and PS3
    Posted Dec 19, 2012 01:14 PM
    I used the same debug process as the original post and also verified with Wireshark running on the DHCP server.
  • 8.  RE: DHCP Fingerprint and PS3
    Posted Dec 19, 2012 01:17 PM
    Okay.  Well we need to find out why it is not working.  There are sometimes 3 parameters that are part of the signatures and the key is to choose the right one and the right format.  If you did a capture and/or DHCP debugging you might have what you need, but the format may be incorrect.  Please consult the document here:  http://www.arubanetworks.com/wp-content/uploads/AOS-DHCP-FingerPrint-AppNote.pdf to ensure that the right parameter is being used.
