last person joined: 2 hours ago
DHCP Fingerprint in large deployment
  • 1.  DHCP Fingerprint in large deployment
    Posted Jan 09, 2020 09:20 AM
    Hello, I'm doing a large deployment of CPPM (20 servers in the cluster - Version 6.8.4) that spreads across three locations. I will have 1 Publisher at local A, 1 Standby-Publisher at local B, and 18 subscriber (6 per each local).
    I saw that I should divide in three zones in clearpass to avoid unecessary traffic between wan links. Then I should set a primary master and secondary master to process the profiling for each zone. Is it correct?
    My other doubt is about DHCP Relay.
    As I know only the Publisher can write the database.
    So, is best to set the ip helper (DHCP relay) directly to the Publisher(In other zone), or is best to point to the Master Server of the zone?
  • 2.  RE: DHCP Fingerprint in large deployment
    Posted Jan 09, 2020 11:36 AM
    Check this document page 37 for more details
    https://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/Command/Core_Download/Default.aspx?EntryId=33256
  • 3.  RE: DHCP Fingerprint in large deployment
    Posted Jan 09, 2020 12:23 PM
    Thank you Pavan... I will configure the Primary and Standby Publisher as the two DHCP Relay.
