DHCP Fingerprinting: Assing VLAN fails on Open SSID
  • 1.  DHCP Fingerprinting: Assing VLAN fails on Open SSID
    Posted Mar 13, 2014 11:25 AM
    I'm trying to do a User Derivation Rule for AppleTVs. The goal is to assign VLAN 220 to this devices, but it fails.
    (wlc-master) #show aaa profile bbva.open
    AAA Profile "open"
    Parameter                           Value
    Initial role                        user
    MAC Authentication Profile          N/A
    MAC Authentication Default Role     guest
    MAC Authentication Server Group     default
    802.1X Authentication Profile       N/A
    802.1X Authentication Default Role  guest
    802.1X Authentication Server Group  N/A
    Download Role from CPPM             Disabled
    L2 Authentication Fail Through      Disabled
    Multiple Server Accounting          Disabled
    User idle timeout                   N/A
    RADIUS Accounting Server Group      N/A
    RADIUS Interim Accounting           Disabled
    XML API server                      N/A
    RFC 3576 server                     N/A
    User derivation rules               test
    Wired to Wireless Roaming           Enabled
    SIP authentication role             N/A
    Device Type Classification          Enabled
    Enforce DHCP                        Disabled
    PAN Firewall Integration            Disabled
    aaa derivation-rules user test
      set vlan condition dhcp-option starts-with "370103060f77fc" set-value "220" description "AppleTVs - 220"
    However, I know that DHCP fingerprintinh this is working fine, because I can assign a role to these devices. If I do:
      set role condition dhcp-option starts-with "370103060f77fc" set-value authenticated
    I see:
    fe80::f6f9:51ff:febc:a220  f4:f9:51:bc:a2:20            authenticated  00:00:02                    AP225-1  Wireless  #cpd11/18:64:72:f9:9c:20/g-HT   open  tunnel        AppleTV  Apple-TV
    10.210.254.241             f4:f9:51:bc:a2:20            authenticated  00:00:02                    AP225-1  Wireless  #cpd11/18:64:72:f9:9c:20/g-HT   open  tunnel        AppleTV  Apple-TV
    It is an Open SSID... maybe is it related? Any idea?
  • 2.  RE: DHCP Fingerprinting: Assing VLAN fails on Open SSID
    Posted Mar 13, 2014 02:21 PM
    Can you try to change it to be 'condition macaddr equals' and see if that works?
    I have just done this yesterday with a HP printer to get it into a particular vlan when they were using vlan-pooling and it worked.
  • 3.  RE: DHCP Fingerprinting: Assing VLAN fails on Open SSID
    Posted Mar 13, 2014 02:43 PM
    Thanks for the suggestion... Looks like the VLAN assignment now works:
    aaa derivation-rules user "ATV-220"
      set vlan condition macaddr equals "f4:f9:51:bc:a2:20" set-value "220" description "AppleTVs - 220"
    (wlc-master) (config) #aaa profile XXXX.open
    (AAA Profile "bbva.open") #user-derivation-rules "ATV-220"
    (wlc-master) (AAA Profile "bbva.open") #!
    (wlc-master) (config) #write memory
    And I can see that now the device connects through VLAN 220, although it doesnt receive an IP address (that can be another network problem).
    fe80::f6f9:51ff:febc:a220  f4:f9:51:bc:a2:20            authenticated  00:00:02                    AP225-1  Wireless  #avbb.cpd11/18:64:72:f9:9c:30/a-HT   XXXX.open  tunnel        AppleTV
    (wlc-local1) #show user mac f4:f9:51:bc:a2:20
    IP address not found
    The phy column shows client's operational capabilities for current association
    Flags: A: Active, B: Band Steerable, H: Hotspot(802.11u) client, K: 802.11K client, R: 802.11R client, W: WMM client, w: 802.11w client
    PHY Details: HT   : High throughput;      20: 20MHz;  40: 40MHz
                 VHT  : Very High throughput; 80: 80MHz; 160: 160MHz; 80p80: 80MHz + 80MHz
                 <n>ss: <n> spatial streams
    Association Table
    Name     bssid              mac                auth  assoc  aid  l-int  essid        vlan-id  tunnel-id  phy             assoc. time  num assoc  Flags  Band steer moves (T/S)
    AP225-1  18:64:72:f9:9c:30  f4:f9:51:bc:a2:20  y     y      3    15     #avbb.cpd11  220      0x100cb    a-HT-40sgi-1ss  7m:29s       1          WAB    0/0
    Why it doesnt work when I use the DHCP Option?
    I'm using AOS 6.4.0.1
    Partition       : 0:1 (/dev/usb/flash2) **Default boot**
    Software Version: ArubaOS 6.4.0.1 (Digitally Signed - Production Build)
    Build number    : 42354
    Label           : 42354
    Built on        : Wed Feb 19 17:09:36 PST 2014
  • 4.  RE: DHCP Fingerprinting: Assing VLAN fails on Open SSID
    Posted Mar 14, 2014 05:39 AM
    Even if it works with a MAC based rule, I need to get it working using the DHCP option... Any suggestion? I know that DHCP option works to assign a role, and I know that VLAN assignment works if it's used with MAC addr condition.... What about the original target? It should work
