Comware
DHCP for Procurve 2810
  • 1.  DHCP for Procurve 2810
    Posted Aug 15, 2022 01:48 PM
    Hello
    I bought the used Procurve 2810. Unfortunately only later I found out that it doesn't have ip helper command.
    I have a DHCP service on the Freebsd server.
    How can I configure the Procurve 2810 that it can get IP addresses for the different VLANs on it?
  • 2.  RE: DHCP for Procurve 2810
    Posted Aug 26, 2022 10:20 AM
    Hello
    ProCurve 2810 is a pure Layer 2 switch. DHCP Relay (ip helper) is a feature of Layer 3 switches because the DHCP packets have to be routed in another subnet. The 2810 is probably connected to a router or Layer 3 switch which is configured with IP interfaces serving as default gateway for the different VLANs. The IP helper should be configured on the router/L3 switch.
    The uplink between the 2810 and the router/routing switch should be configured as a VLAN trunk (or port tagged in all VLANs). This will allow the DHCP traffic from all VLANs to reach the router and from there the DHCP server.
  • 3.  RE: DHCP for Procurve 2810
    Posted Aug 29, 2022 02:16 AM
    I configured the DHCP Relay in the another switch. It helped to resolve my problem.
    Thank you very much.
