dhcp for virtual controller
  • 1.  dhcp for virtual controller
    Posted Dec 18, 2017 05:34 PM
    Hello, I've this Virtual Controller:
    Nome: Aruba Operating System Software
    Tipo: 93
    ora build:2017-11-01 21:31:46 PDT
    Versione:6.4.2.6-4.1.3.5_62133
    IP address: 192.168.1.321
    I need to set up a dhcp to distribute addresses in the 192.168.1.1-192.168.1.127 range but I have some problems.
    These are my settings:
    net = 192.168.1.0
    mask = 255.255.255.128
    But I get this error: "subnet for magic-vlan is overlapping local interface subnet"
    Is there a solution?
    thanks
  • 2.  RE: dhcp for virtual controller
    Posted Dec 19, 2017 01:35 AM
    Hi, are you trying to give the same network for clients that you are using for manage the instant cluster, good luck.
  • 3.  RE: dhcp for virtual controller
    Posted Dec 19, 2017 03:07 AM
    Hello Mesantama
    Frist, we have a little issue with your IAP IP-Address:
    .321 is not valid IP-Address.
    You cannot create an DHCP Range which include the IAP IP-Address.
    Bevor I can help you, we need your correct IAP IP-Address.
    Cheers
  • 4.  RE: dhcp for virtual controller
    Posted Dec 19, 2017 11:20 AM
    This IAP-address is created in the past, now I change it.
    What possibilies in subnet 192.168.252.0?
    After I want an internal dhcp.
    thanks
  • 5.  RE: dhcp for virtual controller
    Posted Dec 19, 2017 12:52 PM
    More clearly, the situation is as follows:
    - gateway: 192.168.1.252/24 with dhcp: 192.168.1.100-192.168.1.100.200 for LAN
    - aruba virtual controller 192.168.1.231 + 10 access points for wifi
    we want to set up aruba so that it has the dhcp with addresses 192.168.1.1-192.168.1.100.100 for wifi devices
    evry try I get the error: "subnet for magic-vlan is overlapping local interface subnet"
    thanks
  • 6.  RE: dhcp for virtual controller
    Posted Dec 20, 2017 08:14 AM
    Perfect, thanks for clarify.
    I tried to create a picture of your topology:
    It looks like the IP Range for the magic VLAN is overlapping (magic VLAN is used for guest access, descripted in short).
    To solve that, try to change the default DHCP Scope to a IP range which you don't need:
