DHCP in controller Mask /16
  • 1.  DHCP in controller Mask /16
    Posted Nov 09, 2015 07:38 PM
    Dear,
    I have a problem for configuring the controller 3200XM  with Network 128.1.50.0/16, but the DHCP in the controller  not work and apply.
    The Network of my customer is configured that's shape.
    Maybe someone have this problem.
    Someone can  help me?
    Regards.
  • 2.  RE: DHCP in controller Mask /16
    Posted Nov 09, 2015 07:40 PM
    Max leases for that controller is 512.
    Tim
  • 3.  RE: DHCP in controller Mask /16
    Posted Nov 09, 2015 07:56 PM
    I know, but it should not work as it supports 512 hosts? What would be the best alternative to solve this problem, as it already has this network with / 16. It does not have DHCP running because it is a network automation and works with Ipfixo, including the access point, but must leave configured DHCP pool for the future they set new APs and maintain the environment.
  • 4.  RE: DHCP in controller Mask /16
    Posted Nov 09, 2015 07:58 PM
    You would need to configure an external DHCP server. You cannot configure a DHCP scope that large on that controller.
    Tim
  • 5.  RE: DHCP in controller Mask /16
    Posted Nov 09, 2015 08:05 PM
    I can change the mask /16 to /24 and access continue the controlller, corretly? In this case, is best and rapid method. do you have some asks?
    thanks.
